Hi
My Microscience HH-725 has suddenly stopped working
This is a "Type 2" 20mb hard disk half height 5 1/4 MFM hard disk
6 month ago I formatted it as an ST 225 with a seagate ST11 controller (formatted it as a ST-225 because it is one of the only compatible options on the controller ROM)
The hard disk worked fine, it had a few bad sectors but just a few (20k or so)
I installed MS-DOS 5.0 and it booted fine
I passed spinrite a few times to try to iron out the bad sectors but some always remained... but the drive was working fine
yesterday I decided to install another language MS-DOS and I connected it, (it had its heads parked), and started normally and booted the previously installed DOS fine
Then I swapped to the floppy disks and started installing DOS.. everything went fine until 97%
At 97% installation suddenly an error message "Cannot write to disk - command.com) (can you bloody believe it had to be command.com ? why not fail to write "compare.com" or "setver.exe" or another non critical file... ??
After that it was always downhill.
Could not boot from it anymore obviously since command.com was not saved properly
I run spinrite 5.0 and it started identifying a few more bad sectors... but not many, just a few "new" ones
At this point i could still run spinrite that was previously saved on the hard disk and I could CD DOS and make "DIR" commands
So I then next tried to low level format it again with the ST11 ROM program
It formatted (I could see the stepper motor slowly rotating) - The stepper motor is not stuck it moves freely
But when the verifying phase started it immediately started retrying to read, right on the 1st cylinder and first head ... read retries
I could do nothing more on the controller ROM program
I then swapped to another controller (a 16 bit western digital controller) and run Speedstor from a floppy disk and the controller test passed, the seek test passed, it could move the heads around from 0 to 612 cylinder
But the read or write tests failed immediately with all "bad sectors"
I tried to initialize it with Speedstor but as soon as it started formatting it it returned with the error "Bad command to drive BIOS"
now the drive is completely inaccessible
The ST11 controller reports "bad drive geometry" when I try to format it with ST-225 parameters and speedstor can only do the seek test, all other tests, initializations fail)
I have tryed the controllers on multiple ISA slots, spraied deoxid and swaped the controller cables around...
Did the drive died in front of my eyes?
I find it strange that a drive that was working only with a few bad sectors has suddenly just stoped working like that
The drive is not making any strange noises, mechanically it behaves normally, I can even issue the park command from speedstor
Can some one with MFM experience help ?
thenk you
Nuno
thenk you
Nuno
