glitch
Alright, I dug out the OS-65U manuals! In the introduction:
Sounds like the end terminals might be doing a little more work than I previously assumed!
I've nearly got the CP/M escort disk working with the system...I've got 48K of static RAM in regular OSI 420 boards. I need the additional 8K starting at $D000, but have been unable to set one of the 420 boards for this RAM address -- I believe, looking from the schematic, that the board sends a "board active" signal, so even though I've got one of them strapped for $C000 and the first and last RAM banks pulled, the board still asserts itself over the system ROMs up at $F000, meaning the machine won't boot.
I do have, IIRC, a OSI 525 card, which is a dual-port RAM card usually used with hard disk controllers (its original purpose in this system) or high-end graphics. It will accomodate several banks of 4K through 2114 static RAMs...it's currently populated with only 4K, at I believe $E000. I can't find a schematic for it, so I can't determine how I should add another 4K to it, as that would be optimal. I do actually have a large quantity of the Molex "Jaguar" connectors that OSI used for the system bus connectors, so I could build a RAM card, but I'd probably have to use smaller RAMs to better accomodate the bus layout. I was considering using a quantity of 6116 static RAMs and a 4-of-16 decoder/demultiplexer, but I haven't had too much time to actually work with the OSI lately.
It /will/ eventually boot CP/M, as I know it has in the past (there are DIR listings from CP/M in the ring-bound manuals my boss gave me)!
OS-65U includes a timesharing executive program that provides file load, save and print functions to up to 16 intelligent terminals (C2-4P's and C2-8P's). This distributed processing allows each of the 16 users to access floppy disk or hard disk sotrage for their BASIC programs and to share a central printer for hard copy listings.
