Model 1 Help
See what you have on Pins 15 & 1 of Z21.
Also see what you have on Pin 4 of Z36. (It should be the same as Z21 Pin 12.
Z36 doesn't look to be the issue, as it has a resistor R48 tied to +5 as a PULLUP resistor.
This means there is +5 volts on the (INPUT) Pin of Z36 unless something is making it LOW.
Larry.
Seens like a bus problem
heres whats on z21 15 & 1
I was looking around and saw you had mention pin 26 of the z80
well I checked mine it goes high when turned on and when you press reset it stays high.
Joe
Pin26 of the Z80 should be HIGH all the time unless you depress the RESET button,
which will make it pulse LOW for a short duration.
Larry
