I have a Model II with the RCA CRT and CRT board. I had the AA11080 power supply in it and swapped it out for an AA11082. After that I have unstable vertical hold. Before I describe the symptoms I will say that I swapped back in the AA11080 power supply and it didn't help.
The symptoms are I can't get the video stable. It keeps rolling. I've tried adjusting the vertical hold on the CRT board and it doesn't help. I can get it to roll very slowly and even sometimes stop rolling for a bit but when it does the screen is is mid-roll with the top line about halfway down the screen. Adjusting the brightness and contrast controls on the front affect the vertical hold as well.
I thought maybe I had bumped something swapping out the power supplies (easy to do with the Model II) so I reseated all the connections on the CRT board and on the CRT. That didn't help.
Any ideas on where to look?
