Capt. 2110
I just got a FREE Motorola MVME133A-20 VMEmodule, and I have absolutely NO IDEA how to use it. Nor how to power it. Nor how to interface to it. I do have a VMEbus mount, however. Anyone know how to use it?
Ok, so now I know it has ROM chips on board,
so how would I connect to that serial port? I see it's a DB-25 port, but I don't know what to do after that.
So, if I connected it to the DB-25 port on an old Win 98 desktop, I could talk to this? Assuming I wire the power correctly?
If you have 117-bug eproms you could try versados. 117 has built in scsi controller, however it requires 117p2 adapter and mvme708 transition board.I've given up trying to find anything to do with the MVME117 board I have.
You'll have better chances to install mvme320
I don't have 117 manual, however I hope this could help:Not all versions have built-in SCSI. The MVME117-4 does not. From what I have seen in photos the built-in SCSI controller chip goes in a 40-pin DIP socket that is stacked on top of a couple of other ICs. The MVME117-4 that I have does not have that socket present so it wouldn't be a simple matter of just inserting the missing SCSI controller chip into a socket. Even if you could do that, then you still have to find the transition boards.
Without even a manual for the MVME117 to know how to configure all of the various jumpers I doubt I will ever do anything with the board I have.
