Don't all MDS800 multibus floppy controllers support FM? I remember working on this disk using the 2-board double-density setup. I thought that all MDS MFM boot floppies had the first track as FM.
I know that the Series 2 integrated floppy controllers did.
CPM224A.IMD is 77 trk, trks 0-2 are SD, the rest are dd. But single sided.
This one won't boot in my Altos 8000-15A which has shugart 801 SS drives, 1797 controller.
And it wont DIR if I've booted from CPM224.
# JAD1 Jade - SSDD 8" - 128 x 48
diskdef jad1
seclen 128
tracks 77
sectrk 48
blocksize 2048
maxdir 64
skew 1
boottrk 2
os 2.2
end
# libdsk data below
[jad1]
description = JAD1 Jade - SSDD 8" - 128 x 48
cylinders = 77
heads = 1
secsize = 128
sectors = 48
secbase = 1
datarate = ED
#Flashfloppy/GOTEK
[jad1]
cyls = 77
heads = 1
secs = 48
interleave = 1
bps = 128
id = 1
rpm = 360
#rpm = 300
rate = 250
mode = mfm
iam = no
$ cpmls -f jad1 -D ADX.RAW
Name Bytes Recs Attr update create
ADXSETUP.DIA 4K 23
ALLOC .DIA 8K 60
BOOTCOPY.DIA 2K 12
CPUTST85.DIA 4K 17
FLPY .DIA 40K 320
FLPYFORM.DIA 4K 23
FLPYTEST.DIA 6K 36
HARDS8 .DIA 26K 206
HRDINIT8.DIA 6K 48
MEMTEST .DIA 2K 14
PRNTEST .DIA 2K 3
SCAN .DIA 2K 12
12 Files occupying 106K, 354K Free.
# A1 Generic CP/M - SSSD 8" - 128 x 26
diskdef a1
seclen 128
tracks 77
sectrk 26
blocksize 1024
maxdir 64
skew 6
boottrk 2
os 2.2
end
# libdsk data below
[a1]
description = A1 Generic CP/M - SSSD 8" - 128 x 26
cylinders = 77
heads = 1
secsize = 128
sectors = 26
secbase = 1
datarate = HD
#Flashfloppy/GOTEK
[a1]
cyls = 77
heads = 1
secs = 26
interleave = 6
bps = 128
id = 1
rpm = 360
#rpm = 300
rate = 125
mode = fm
iam = no
$ cpmls -f a1 -D CPM224.RAW
ALL .EQU 5K 39
ASM .COM 8K 64
BIOSINFO.DOC 24K 192
BOOT224 .MAC 6K 48
CBIOS .MAC 100K 797
CBIOS64 .COM 4K 25
CPMSETUP.COM 4K 32
DDT .COM 5K 38
DISKDEF .LIB 7K 49
DISKSTAT.COM 2K 9
DUMP .COM 1K 4
ED .COM 7K 52
LDRBIOS .MAC 34K 268
LOAD .COM 2K 14
MODE .COM 2K 11
MOVCPM .COM 11K 84
PIP .COM 8K 58
STAT .COM 6K 41
SUBMIT .COM 2K 10
SYSGEN .COM 2K 10
XSUB .COM 1K 6
21 Files occupying 241K, 7K Free.
diskdef a1
seclen 128
tracks 77
sectrk 26
blocksize 1024
maxdir 64
skew 6
boottrk 2
os 2.2
end
# libdsk data below
[a1]
cylinders = 77
heads = 1
secsize = 128
sectors = 26
secbase = 1
datarate = HD
#Flashfloppy/GOTEK
[a1]
cyls = 77
heads = 1
secs = 26
interleave = 6
bps = 128
id = 1
rpm = 360
#rpm = 300
rate = 125
mode = fm
iam = no
$ cpmls -f a1 -D CPM224A.RAW
ASM .COM 8K 64
BIOS224A.MAC 7K 51
BIOS224B.MAC 8K 61
BIOS224C.MAC 3K 22
BIOS224D.MAC 20K 157
BIOS224E.MAC 48K 384
BIOS224F.MAC 30K 240
BIOS224G.MAC 18K 144
BIOS224H.MAC 29K 226
BOOT224 .MAC 6K 48
BPTBPB .EQU 1K 7
DISKDEF .LIB 7K 49
DISKSTAT.COM 2K 9
DUMP .COM 1K 4
ED .COM 7K 52
MOVCPM .COM 11K 84
PDB .EQU 3K 19
PIP .COM 8K 58
PTIOB .EQU 1K 4
STAT .COM 6K 41
SUBMIT .COM 2K 10
SYSGEN .COM 2K 10
XSUB .COM 1K 6
24 Files occupying 72K, 176K Free.
diskdef a1
seclen 128
tracks 77
sectrk 26
blocksize 1024
maxdir 64
skew 6
boottrk 2
os 2.2
end
# libdsk data below
[a1]
cylinders = 77
heads = 1
secsize = 128
sectors = 26
secbase = 1
datarate = HD
#Flashfloppy/GOTEK
[a1]
cyls = 77
heads = 1
secs = 26
interleave = 6
bps = 128
id = 1
rpm = 360
#rpm = 300
rate = 125
mode = fm
iam = no
$ cpmls -f a1 -D MPM11.RAW
ABORT .PRL 1K 5
ABORT .RSP 1K 5
ASM .PRL 10K 74
ASMPRL .SUB 1K 6
ASMSPR .SUB 1K 6
BASE0000.ASM 1K 1
BASE0100.ASM 1K 1
BASE0200.ASM 1K 1
BDOS .SPR 6K 47
BNKBDOS .SPR 5K 33
BOOT .ASM 2K 15
CONSOLE .PRL 1K 4
D25 .ASM 1K 1
D25 .BAK 0K 0
DCS2XIOS.ASM 19K 151
DDT .COM 6K 42
DEBLOCK .ASM 10K 80
DIR .PRL 1K 8
DISKDEF .LIB 7K 49
DSKRESET.PRL 1K 5
DUMP .ASM 5K 34
ED .PRL 8K 60
ERA .PRL 1K 6
ERAQ .PRL 3K 21
GENHEX .COM 1K 6
GENMOD .COM 2K 10
GENSYS .COM 8K 60
LDRBIOS .ASM 8K 64
LOAD .COM 2K 14
MACPRL .SUB 1K 5
MACSPR .SUB 1K 3
MDSXIOS .ASM 17K 132
MPM .SYS 22K 176
MPMLDR .COM 6K 48
MPMSTAT .PRL 4K 29
MPMSTAT .RSP 4K 30
ODOS .SPR 3K 20
PIP .PRL 9K 69
PRLCOM .PRL 2K 11
RDT .PRL 7K 50
REN .PRL 1K 6
SCHED .PRL 3K 20
SCHED .RSP 2K 13
SPOOL .PRL 2K 13
SPOOL .RSP 2K 11
STAT .PRL 12K 91
STOPSPLR.PRL 1K 5
SUBMIT .PRL 5K 33
SYSTEM .DAT 1K 2
TOD .PRL 3K 20
TYPE .PRL 1K 6
USER .PRL 1K 7
XDOS .SPR 9K 72
XIOS .SPR 2K 12
54 Files occupying 235K, 13K Free.
diskdef a1
seclen 128
tracks 77
sectrk 26
blocksize 1024
maxdir 64
skew 6
boottrk 2
os 2.2
end
# libdsk data below
[a1]
cylinders = 77
heads = 1
secsize = 128
sectors = 26
secbase = 1
datarate = HD
#Flashfloppy/GOTEK
[a1]
cyls = 77
heads = 1
secs = 26
interleave = 6
bps = 128
id = 1
rpm = 360
#rpm = 300
rate = 125
mode = fm
iam = no
$ cpmls -f a1 -D MPMII_1.RAW
ABORT .PRL 1K 5
ABORT .RSP 1K 5
ASM .PRL 10K 74
BNKBDOS .SPR 11K 81
BNKXDOS .SPR 1K 7
CONSOLE .PRL 1K 4
DDT .COM 6K 42
DIR .PRL 2K 14
DSKRESET.PRL 1K 5
DUMP .PRL 1K 6
ED .PRL 9K 68
ERA .PRL 2K 15
ERAQ .PRL 4K 29
GENHEX .COM 1K 6
GENMOD .COM 2K 10
GENSYS .COM 10K 74
LOAD .COM 2K 14
MPMLDR .COM 6K 45
MPMSTAT .BRS 5K 33
MPMSTAT .PRL 5K 33
MPMSTAT .RSP 1K 3
PIP .PRL 10K 77
PRINTER .PRL 1K 8
PRLCOM .PRL 3K 21
RDT .PRL 7K 50
REN .PRL 3K 19
RESBDOS .SPR 4K 29
SCHED .BRS 2K 12
SCHED .PRL 3K 20
SCHED .RSP 1K 3
SDIR .PRL 18K 137
SET .PRL 8K 60
SHOW .PRL 8K 60
SPOOL .BRS 3K 20
SPOOL .PRL 3K 17
SPOOL .RSP 1K 5
STAT .PRL 10K 78
STOPSPLR.PRL 1K 5
SUBMIT .PRL 6K 42
TMP .SPR 2K 11
TOD .PRL 3K 20
TYPE .PRL 2K 11
USER .PRL 1K 8
XDOS .SPR 10K 79
44 Files occupying 192K, 56K Free.
diskdef a1
seclen 128
tracks 77
sectrk 26
blocksize 1024
maxdir 64
skew 6
boottrk 2
os 2.2
end
# libdsk data below
[a1]
cylinders = 77
heads = 1
secsize = 128
sectors = 26
secbase = 1
datarate = HD
#Flashfloppy/GOTEK
[a1]
cyls = 77
heads = 1
secs = 26
interleave = 6
bps = 128
id = 1
rpm = 360
#rpm = 300
rate = 125
mode = fm
iam = no
$ cpmls -f a1 -D MPMII_2.RAW
BOOT .ASM 2K 15
BUTTONS .LIB 1K 4
COMPARE .LIB 2K 9
DEBLOCK .ASM 10K 80
DISK .DOC 2K 10
DISKDEF .LIB 7K 51
DOWHILE .LIB 1K 7
DSTACK .LIB 10K 80
DUMP .ASM 5K 36
EXTRN .ASM 1K 2
I8085 .LIB 1K 3
INTER .LIB 3K 17
LDRBIOS .ASM 8K 64
LIB .COM 7K 56
LINK .COM 16K 122
NCOMPARE.LIB 2K 10
RESXIOS .ASM 20K 154
RMAC .COM 14K 106
SELECT .LIB 2K 13
SEQIO .LIB 11K 82
SIMPIO .LIB 1K 5
STACK .LIB 2K 9
TODCNV .ASM 16K 126
TREADLES.LIB 1K 5
WHEN .LIB 1K 7
XREF .COM 16K 121
Z80 .DOC 9K 70
Z80 .LIB 6K 47
28 Files occupying 177K, 71K Free.
