fjk61011
Tring to set up sntp. What parameter for ireland at the moment gmt/utc + 1
It never could have worked in the past few years without setting the TZ environment variable correctly - it has no way of knowing your timezone or local daylight savings time rules.Haven't worked it out yet. Used to work without all the parameters
This seems to work for Dublin. You have to copy whole string. For my location only the first part is sufficient..posix_tz_db/zones.csv at master · nayarsystems/posix_tz_db
Generates POSIX timezones strings. Contribute to nayarsystems/posix_tz_db development by creating an account on GitHub.github.com
I had set the TZ but it seemed to be shorter if I remember. I'm enjoying the IRCjr. Working well.It never could have worked in the past few years without setting the TZ environment variable correctly - it has no way of knowing your timezone or local daylight savings time rules.
It is possible that the compiler runtime accidentally had a good default for you but highly unlikely.
I'll try that.This seems to work for Dublin. You have to copy whole string. For my location only the first part is sufficient..posix_tz_db/zones.csv at master · nayarsystems/posix_tz_db
