erik_james
- Joined
- Sep 10, 2005
- Messages
- 22
Delete please
erik_james said:Ok, a bit of an update.
I took the computer down to the computer shop in my area and the guy seemed quite interested in it. He told me that the disk drive on the side is a pcmcia flash drive (only problem is that the computer cannot properly boot without it) so he showed me a flash drive that he had instock but he explaned to me that my computer is not compadible with the newer type flash drives (like the disk fit's inside properly but it has something to do with how many bits are on the flash drive) long story short, I need to find a 16 bit pcmcia flash drive (which he told me would be quite hard to find) I found this one on ebay but I'm not sure if its compadible with my computer or not (and I cannot go back to the computer store becasue he will be closed sunday and monday and the auction ends tommrow)
http://cgi.ebay.ca/NEW-SOHOWARE-16-...ameZWD2VQQrdZ1QQcmdZViewItem#ebayphotohosting
I know the flash card on the link is a 16 bit so it looks like it should be fine.
Here's some info on the computer itself (so maby someone can help me out)
Main Processer : 80386SX Base Memory Size : 640 KB
Numeric Processer : None Ext. Memory Size : 3456 KB
Flopy Drive A: : None Hard Disk C: Type : None
Flopy Drive B: : None Hard Disk D: Type : None
Display Type :VGA/PGA/EGA Serial port(s) : 3F8,2F8
AMIBIOS Date :06/06/92 Parallel Port(s) : None
erik_james said:So would this type of card work? (I wont it off ebay) It's designed for an apple computer but im sure it would be easy to reformat.
http://cgi.ebay.ca/4Mb-Fast-Flash-M...5239248456QQcategoryZ3710QQrdZ1QQcmdZViewItem
I'll try and get some actual pics of the disk drive within the next few hours so I can show you exactly what im working with.
and yes the 2 shots are stacked on top of each other.
Erik
