glitch
I've finally gotten a copy of Kermit-86 up and running on my NEC APC under CP/M-86 -- now the trouble is I'm not sure that it works. Loopback tests fail. The APC uses Centronics 36-pin connectors for both parallel and serial connections, so I thought perhaps it was a weird pinout that I was goofing up. I got out my 8251 "test socket" (a DIP socket with pins 3 and 19 bent up and soldered together -- RxD to TxD directly) and still no loopback. I've changed the 8251A with a known good device, too. I haven't gone further in testing as the board is hard to probe while in the slot, and I don't have an extender for the APC. Any ideas?
