- Make sure the jumpers on the board are properly configured
- Remove and reseat the RAM and the expantion cards
- Look for the mainboard battery. If it is barrel shaped you need to remove it to prevent corrotion. If you see green-colored traces whose sourse is the battery then some damage on the board is already done. The metals that suffer from corrotion will have decreased conductivity and it might fatal on some occations.
- Next thing to check is the PSU. Having a voltage meter is useful to check if the voltages are close to what they intend to be or not.
- The capacitors on the board are the most frequently failing parts, especially those tantalum early boards tend to use, but usually when they fail, they fail opened and this should not prevent the board from booting. In the rare case that they fail shorted they can cause serious problems. They are usually a pain in the rear because they often have failed but visually look OK and you cannot test them without removing them from the board.
- The RAM is another part that can cause the board not to start if it is bad, incompatible with the board, or even inserted in the wrong bank
