daver2
10k Member
No problem.
My 10 cents (for what it's worth) is:
If you are going to use the DEC case, power supply and QBUS backplane - I would stick with the 11/73 CPU and QBUS memory (to keep it hardware authentic).
It now depends what you are going to do with the system after that...
I would migrate to a DLV11-J serial card and the TU58 emulator next - as it involves the minimum of hardware within the QBUS box. As I said, happy to put you one in the post 'free gratis' - but it won't get to you now to open it on Christmas morning :-(!
This would get you the XXDP diagnostics and RT-11 (and be as close to DEC equipment as possible - but without the physical 'disk/tape' media).
You can obtain modified DD drivers for RT-11 (and I would guess RSX-11) to be able to drive the TU58 emulator as a large disk drive (much larger than than the tapes). With a fast serial line interface you will probably achieve similar speeds to a real (slow) disk drive?
You can then identify whether you want to move on to the RQDX3 and try to get that working with either a real DEC RDxx disk - or one of the RDxx disk emulators). The alternative would be to find a QBUS SCSI card and one of the SCSI2SD or SCSI2CF interfaces. These work brilliantly. XXDP would be paramount to testing out your RQDX3 and RDxx chain.
You could also consider QBONE to emulate the disk devices...
