I have had an old ST251-01 sitting on a shelf for a while, but didn't have a controller to drive it. Today I picked up an old IMB 5150, which had a WD1002S-WX2 controller in it, but no HDD.
So I put 1+1 together, so to speak, and tried to low level format the drive. The first try succeeded according to the LL format tool in the ROM of the card, but it only formatted 10MB. I ran FDISK, and got some odd noise from the drive while generating the partition, but it did say it succeeded. Reboot, format c:, got to around 10% or so, and then says format failed after a few "attempting to recover ...". So I'm sure there are some bad sectors on this drive. What I don't understand is why Format gave up? I thought it would just continue and mark those sectors bad.. Or is there some threshold? I tried with both DOS 6.22 and DOS 3.30. Both behaved identically with the high level format. After about 10%, they just gave up.
I figured out how to set the jumpers for 20MB, but the LL format was taking so much longer with many recalibrations (the stepper driving back to track 0) that I just gave up on that.
So .. I have a number of questions:
1. The drive does not have the termination resistor pack on it, could that be the cause of the noise during low level format & FDisk and the high level format failing?
2. The controller supports up to 20MB drives with slightly different geometry than the ST251. However, the geometry of the 10MB and 20MB selections on the controller fits in the geometry of the ST251. I assume that not using some cylinders and heads shouldn't cause issues with the drive, correct?
3. Based on all this, what are the chances this drive would work ok with a resistor pack and another controller?
Thanks!
Thanks!
