Hi, I usually try to find the solution before asking for help, but this time I run out of ideas.
I'm trying to setup some sort of "tweenie" system (its a P3/650Mhz on some generic i810 mobo).
My goal is to have to dual boot DOS and Win XP of the CF card in the first IDE chanel, have CDrom on secondary and
dual floppies.
Hardwarewise everything seems to cooperate, I partitioned the CF (32GB Sandisk) in 2 partitions , 1GB for DOS and
the rest for XP.
DOS 7.1 instaled smoothly, I boot from Windows instll CD and bam! "windows cannot instal to removable drive".
Looks like I'have rediscovered the famous "removable versus fixed bit " problem.
Fine, found a supposed fix , a program named atcfwchg.com , that is supposed to change the bit from removable to
fixed.
I run it from pure DOS, comes with fail message , error 7 and from within XP at CMD prompt, returns error 20.
Now, I know I can buy a different CF card but they don't come cheap anymore, is there a solution?
Ideally I need a way to turn that damn Sandisk CF into a fixed disk mode.
If this turns out to be impossible, i'm open to other possible solutions, here's my order of preference:
1 somehow turn the damn bit to "fixed"
2 find another way to install and succesfully run dualboot DOS/Xp on the same disk
3 Try to run dualboot DOS/linux (what kind?.)
All I really needed XP for was to be able to easyly browse the net and Lan.
dual floppies.
the rest for XP.
fixed.
