So the power switch on my commodore PET 2001-8 just seized up and broke. I got the thing out and thought I had a similar rocker switch that would fit, but nope!
Can someone please help me source a new power switch?
Chuck no illumination, just on off. Only two posts were connected. Not sure as to why they used this switch. Yep I broke the ears off to make getting it out easier.. Tight fit behind that massive transformer.
Because they were cheaper and more common than SPST switches.
Those switches are as common as dirt, except that they come in both inch and metric standards. Ratio Shahbaz (thank you auto correct) used to sell suitable replacements. Mouser, Digikey, Farnell, etc.. have them but like Chuck (G) wrote, you'll have to measure it. Once you have dimensions it should be a piece of cake finding one.
An interesting sidelight on the Chineseium ones--the 2-terminal non-illuminated ones are exactly the same in construction as the 3-terminal illuminated ones. The difference is the terminal and inclusion of a small neon lamp. The actuator itself is the same. The strange thing is that the neon-lamp ones are a little cheaper.
