Old PC Man
- Joined
- Jul 24, 2003
- Messages
- 24
My 5170 has a WD 1003-WA2 Windchester/Floppy Drive controller. The floppies are working fine but my Seagate ST225 HD is not. I know it is not the HD. I tested the HD in an old IBM PC and it worked fine. I've double checked the HD Drive Select setting and it's OK. I've changed out both ribbon cables and that didn't help. The controller seems to be communicating with the HD since the FDISK command worked. I just can't partition the drive. The HD just makes a noise and then hangs.
I downloaded some information on the controller from WD but the information WD provided doesn't match the controller I have. I noticed that pin 15 is missing on the 34 pin controller connection and pin 8 is missing on the 20 pin connection. I haven't seen this arrangement before and I'm wondering if special cables are needed.
I'm also wondering if the controller is for RLL Drives.
The CMOS drive type I selected is Type 2.
Any help on this problem will be appreciated.
Thanks
Old PC Man
Thanks
Old PC Man
