per
It should be possible, if you got some digital-cirquicy experience, to make a device that read bytes sendt out from the Keyboard port. Checkpoint bytes are sendt out of the keyboard port if the system get past the essencial MoBo tests (processor, DMA, ect...). If any bytes are sendt out, you would know that the MoBo starts, and be able to find out on what test it fails.
However, only internal testers at IBM in the 80's had sutch equipment, so I really don't know if you would be able to make one. You problably need some kind of a shift register, but that's as far as I know.
If it is that the MoBo is faulty, you could replace the BIOS with a custom BIOS designed for repairing. you would problably need a bus examining card in addition to this. I haven't tried to repair a motherboard bfore, but I know some other peoples here have experience with it.
