Need help writing an IMG file to 5.25" floppy
DeltaDon
Dutchess County, New York, USA
I've D/L'ed from brijohn's github the msdos2.11.img for the Epson QX-16 and am trying to write a copy of i. I'm using the following setup: Greaseweazle 4.0 running GUI interface to a Panasonic JU-475-4 drive and have selected to write a img file.
The msdos211.img is selected. I've failed in writing it to the disk several times. I don't know the correct format to use for the write. I've tried several IBM formats, but all seem to fail. My Epson has 5.25" drives DSDD with about 720K size.
So do I need a special Epson format? If so, how do I create it or find a copy to load into the GW software?
Don,
I processed the *.IMD files along with creating a MSDOS211*.SCP file that the Greaseweazle should write correctly.
(((512 * 9) * 2) * 40) = 368640
If you wanted to use the Imagedisk utility BIN2IMD to write a MSDOS211.IMD file here is a MSDOS211.B2I
file that should work properly.
MSDOS211.B2I
; BIN2IMD MSDOS211.RAW MSDOS211.IMD MSDOS211.B2I
0  N=40 DM=5 SS=512 SM=1-9 /1
1  DM=5 SS=512 SM=1-9 /2
Larry
  • QX-10_Images.zip
