Chuck(G)
25k Member
Nice pick on your new board. I'm wondering if the BIOS supports 2 floppys or is it an either/or choice?
Just a single floppy as far as I can tell.
But it sounds like Chuck has his motherboard sorted, other than the MFM 128 byte sector issue.
Hmmm, Chuck, does the test also test for FM 128 byte sector reads? To image TRS-80 Model II boot disks this would be required.
If so, just use an external toggle switch to select which drive it talks to.Chuck(G) said:Just a single floppy as far as I can tell.
I installed a toggle switch and LED on my NorthStar MDS in the late '70s just to avoid messing with write protect tabs.
Better than Mr. Miyagi's advice, "Tab on... Tab off..."
