modem7
10k Member
Your motherboard has a Phoenix BIOS, whereas what I pointed you to is the DTK/ERSO BIOS on my motherboard. The content will be quite different.Thanks a lot for that, as soon as i have some time i will compare the content of my bios ship and your image file !
On the web page that I pointed to, there is what I think is an earlier version of your Phoenix BIOS, version 2.51. You have version 2.52
It is highly unlikly that the motherboard BIOS is the problem cause. And that is supported by the fact that the FileCard still did not work when you moved it to your IBM 5160, a system that I expect to be compatible with the FileCard (assumption: you first removed any existing hard disk controller).
for the moment i'm waiting for the replacement controller.
His only chance is to get data out of that old hard drive !
If there is any good software for this purpose please let me know ..
Because the WD1002-27X may be the faulty part, you are best to try the replacement WD1002-27X first. Set the jumpers the same as what is on the existing WD1002-27X. If no success, try swapping the ROMS between the two WD1002-27X cards (in case the ROMs contain different drive tables).
I presume that you have already disconnected the cables between the WD1002-27X and drive, and then reconnected them (to fix any poor electrical contact).
