k2x4b524[
This weekend, i went down to Hillsboro from Seattle and got some things.
1-IBM 5160
1-IBM 5150
1-IBM 5151
3-Boxes of books
The 5160 had the following
Half height Teac FD55-BV 360k
Seagate ST-412
2x memory cards - An IBM 64-256kb memory expansion with 256kb on it, and an Everex EV 183 with 128kb on it *This gives the XT its 640kb load out
Paradise Autoswitching EGA adapter
Standard floppy controller
The 5150 had the following
2x full height floppy drives
Winbond hercules video *without the extra rom*
A quadram quadboard with 256kb installed
IBM 5161 Extender card *now i want to find thd receiver and chassis
My questions:
The Teac 55-BV will format a 360kb here and there, but will default to single sided formats. I took a q-tip and skimmed between the heads, and got a bunch of hairs. What elst might be causing a 360 to defult to 180
The ST-412.. Bless it..
It powered on, but no love from the spindle
The platters would wiggle, barely but nothing
Head assembly was free as a bird
The spindle needed help in the form of me turning it back and forth a couple of times between power cycles. Scared the lady friend when it broke free and spun up. It is now spinning, upside down *found a previous thread* And for the most part is running at normal sound level with the occasional ping, poing and scrape. I figure if i let it run for a couple of days like this, as mentioned, it might return to normal operational sound. Which brings me to my next question.
Is there any way to lube this thing? The thread i found mentioned a channel you could squirt some wd-40 enriched with light machine oil, or white lithium aresol, which i have some of *The aresol*, but can't seem to find the channel with which to use the white lithium *i see a small groove just under the edge of the spindle motor, but am not sure this is it*
The EGA card - Can you use a mono monitor with it if the card is set to drive a mono display? The 5151 doesn't care for it, neither does the Goldstar mono that i have
The Winbond hercules card - The PC and XT see it as a standard mono card, and every regular hercules card i find online, has a driver disk with it. The winbond one doesn't. Are there generic hercules drivers floating around i can use? The chipset is W86855af, 64kb on board, googles as a hercules chipset
On full height maintenence - I have already restored 3 Tandons to operation by lubricating the slide rails for the heads, but is there anything i can do for the stepper motors? Surely, they've grease that dries out at some point too?
On to the box of books:
IBM Technical reference 2.02
IBM Technical reference for XT and Portable
IBM Hardware Maintenence and Service for PC-XT Vol 1-3 Complete - With advanced diags
IBM Hardware Maintenence and service for PC Vol 1-2 *The binder for 3 was empty* With advanced diags
IBM Macro Assember *No Disk*
Dos 2.0 Technical reference
IBM Guide to Operations for PC and XT *Various revisions /w disks*
IBM Easy Writer /w disks
3rd party guide to IBM resources *just a compilation of resources that IBM authorized*
Peter Norton guide to DOS
And assorted addendum pages to the IBM manuals *Still shrink wrapped*
1-IBM 5160
1-IBM 5150
1-IBM 5151
3-Boxes of books
Seagate ST-412
My questions:
