ScutBoy
I recently came into an 11/23+ machine. It has a KDJ11-B CPU board, a MSV11-Q memory board, a SCSI board that was driving a SCSI Zip drive for boot media, and two cards that were used to control a laser cutter.
First issue is that there is no "bulkhead" to bring out the console connection, so I need to figure out how to get a terminal connected to the J1 SLU connector. This is 9 pins, but I can't seem to find definitive info on what the pin assignments are here, and exactly which pin is #1. Once I know these things, I'm sure I can make a cable with TX/RX/GND to get a console going. Anyone have pointers? I found a set of schematics but what I think is showing J1 doesn't make sense to me.
Then, I need to figure out how to get software set up to run the thing. I didn't receive any of the Zip media previously used, or any documentation for the machine. I'm guessing I can use SIMH and perhaps build a bootable Zip or other SCSI drive, but that will need to wait until I can at least talk to the thing. Lacking any other serial ports, I don't think I'll be able to take advantage fo the TU58 emulator or other solutions.
Looking forward to getting this guy up and running!
