facattack
Using ADTPRO as a transfer software, what other software/steps do I need to take to backup my IIGS's hard drive?
Once you've asked ADTPro to transfer the image, copy that image somewhere. That image _is_ your backup. You can review its contents with the likes of CiderPress or AppleCommander, zip it (or not), and stash it somewhere. You can send that image back to the IIgs' hard drive any time you like to get back to that exact same point in time you transferred it.Using ADTPRO as a transfer software, what other software/steps do I need to take to backup my IIGS's hard drive?
.shk is ShrinkIt format; it's like .zip for Apple II's. You need to UnShrink it and then get it written to a disk image. It's going to be a bit of a multi-step process. Are you still trying to back up your disk drive? Asimov isn't quite the right tool for that...Darn. I heard Asmiov was a good program to use but when I downloaded it from Ninja Force it was in .shk format. It won't transfer properly over ADTPRO without complaint. What should I do?
