1ST1
I have two of the Chuanganzuhuo USB floppy 1.4 drives, each attached to a Win10 machine, and both are able to read from and write to floppy disks. Another brand of drive I tried earlier was not successful, so it may be partly the fault of the hardware.
These are the good ones. (In fact they are also chingchangchung Ye-Data, but old ones)
It's just working, Win 10 20H2 fully patched.
Maybe the trick is, attaching the drives not directly to the computer, but plug them on an active USB hub. Active means, it has it's own separate power supply. Computer's USB ports often seems to be too weak to supply USB floppy drives. That is also important for USB zip drives.
And if you prefer mechanically more stable drives, see this: https://www.ebay.com/itm/USB-Cable-...882919?hash=item4b6038cee7:g:h3UAAOSwOztciruc But I have no experience if they support also 720 kb diskettes. The offer only talks about 1.44 MB, like on those modern offers for 3,5 inch slim floppy drives with housing. . I will see end of january 2021, I have ordered one of these adapters just recently, it will take it's time to arrive from China.
But floppy is not the ideal media to transfer a huge amount of data from modern PC / Mac to old system. It's necessary for the beginnimg when the machine is not installed, but afterwards I prefer USB / Parallel Port / SCSI ZIP drives and ParCP-USB (which is something like laplink between Win XP...10 / Mac / Linux and Atari ST or MS-DOS (386SX and newer) on the old side). I just installed my Olivetti M380XP9, that's a huge 80386-33 tower using floppy to install MS-DOS and copy guest.exe onto it, and then transfered Windows 3.11 plus updates and software, DOS tools, Games, demos etc. over to it by ZIP drives. The machine has 350+650 MB SCSI drive and now both drives are 90% filled. Another simple way for data transfer is, if the old computer has IDE interface and can read FAT16 partitions, then I use Compactflash card with IDE adapter - this even works with Atari ST computers if they have IDE (like Falcon 030 does). Another experiment soon will be mtcp, I am unhappy about compatibility of network protocol between Win for Workgroups 3.11 and Win 10...
