themaritimegirl
Just wondering if anyone has any opinions regarding which suite you prefer, and why. I've always used NU on my DOS machines (8.0 on the 486 and 6.0 on the XT), but I would like to try PC Tools sometime.
Why not both? You can have both installed on the same drive without any problem (I do). For the XT NU 4.5 and PC Tools 4.30 (classic interface, very retro) or 5.x are fine and for the 486 NU 8.0 and PC Tools 9.0 (it does not support MS-DOS 6.22 drivespace). PC Tools package an impressive amount of utilities and NU have a more professional feeling, IMHO. Ah, and don't forget Mace Utilities!!
I use 4.5 AE and it's plenty capable.
I have Mace Utilities on 5.25's. They didn't hang around very long.
Norton Utils 4.5 works perfectly with PC/MS-DOS 4.0 "bigdos" partitions up to 2GB. NU 4.5 was the first version to support that (NU 4.0 did not), but never had a problem with it.I don't think diskedit 4.5 in "logical" mode works with FAT16 filesystems, but I could be wrong. In other words, I'd only run 4.5 on DOS 3.3 and lower.
?????I don't think diskedit 4.5 in "logical" mode works with FAT16 filesystems, but I could be wrong. In other words, I'd only run 4.5 on DOS 3.3 and lower.
There's no diskedit in NU 4.5 AE. You must have a later version in mind.
Yes, that's right. All partitions fdisk'd and formatted with DOS 5.00.
It's a turbo XT with XTIDE controlling the 4GB CF card. I should be able to report back in a few hours with the actual error message.
My guess is that these partitions are actually FAT32. (Your 512MB partition is the real giveaway.)Or even sooner: "NDD will not work with drives having more than 8K bytes per sector or 16K bytes per cluster."
Using /dev/sdc
Welcome to GNU Parted! Type 'help' to view a list of commands.
(parted) p
Model: Generic STORAGE DEVICE (scsi)
Disk /dev/sdc: 4035MB
Sector size (logical/physical): 512B/512B
Partition Table: msdos
Number Start End Size Type File system Flags
1 32.3kB 504MB 504MB primary fat16 boot
2 504MB 4030MB 3526MB extended
5 504MB 2077MB 1573MB logical fat16
6 2077MB 4030MB 1953MB logical fat16
(parted) q
That would certainly be a logical conclusion, but DOS 5.00 can access them just fine, and that's what I used to create them. Here's a view of that CF card under Linux:
Code:Using /dev/sdc Welcome to GNU Parted! Type 'help' to view a list of commands. (parted) p Model: Generic STORAGE DEVICE (scsi) Disk /dev/sdc: 4035MB Sector size (logical/physical): 512B/512B Partition Table: msdos Number Start End Size Type File system Flags 1 32.3kB 504MB 504MB primary fat16 boot 2 504MB 4030MB 3526MB extended 5 504MB 2077MB 1573MB logical fat16 6 2077MB 4030MB 1953MB logical fat16 (parted) q #
It is a conundrum...
