Odd, old IBM CGA board (1804464)
VileR
Israel
Here's a card that just came in the mail. 1804464 was one of those "unknown type" CGA P/Ns (see this old thread) - i.e., it wasn't known whether it had an older-style or newer-style composite video output.
Having tested it now on my TV, I can confirm that it definitely shows an older-style output. However, there are a couple of oddities about this board.
First, there's all this wiring around the back (click for full size):
I haven't the slightest clue what this is for, but it looks neat enough that I don't think it's someone's custom job. Could it have been shipped out of the factory like that? Correction for a defective batch perhaps?
Then there's the composite output stage (click):
Only 6 DAC resistors here - as far as I can recall, other old-style IBM CGAs have 7. This one is missing R17 (next to R1 and R4), and there's no silk-screening or pads for it either (as opposed to R9..R16).
Looking at the TV output, I can't distinguish anything really different from what I'd expect for an old-style CGA. That is, 8088MPH shows the right colors; the initial 'which CGA' screen reports "OLD"; etc. I could take a few TV photos if that would help, but I suspect it wouldn't, since I don't currently have another old-style CGA to compare against on the same TV.
What could be the significance of the missing resistor, then? @reenigne? anyone? :)
Normally on old CGA, R1 and R17 form a voltage divider to reduce the overall voltage of the composite output to 3/4 of what it would otherwise be. I'm guessing this was a very early version where they didn't realise that reduction was necessary - perhaps after this card was designed they found some monitors that couldn't handle such a high signal. Strangely, the new-CGA schematic in the Options and Adapters manual also lacks this resistor, but has a higher value for R4 - I'm guessing that acts to reduce the signal in the same way, just with fewer resistors.
Nice - yep, same yellow wiring and very similar date codes, so I guess that answers my first question. Although I was also curious about the narrow 5160-style bracket on my card... for a mid-1982 card I'd expect a black wide 5150-style bracket like yours.
Interesting, thanks! Makes sense, even if it doesn't entirely clear up the odd timeline of those revisions...
A couple of observations after playing with this board some more. Compared with the output of a 'new-style' CGA:
- In color modes, the image has a much higher contrast.
- In B&W modes, the image has a much higher brightness (i.e. while color 0 appears black with the burst enabled, it's a mid-grey with the burst disabled).
I suppose this could be explained by the card giving out a 'hotter' signal, as mentioned? Since the presence of a colorburst also triggers some normalization of levels on the TV side, I could see how the two cases might be related.
