antiquekid3
Hi all,
I recently saved a Marquette MUSE system from Memphis, TN. It came with an 11/73 CPU, a CDC SMD drive, a Fujitsu Super Eagle hard drive, and various other goodies.
http://i.imgur.com/3hUB3Nd.jpg
http://i.imgur.com/wDvFzWS.jpg
http://i.imgur.com/js8FW28.jpg
It was supposedly powered up in the early 2000s, so I figured it'd be safe to power it up now without doing much. Just to be on the safe side, I only powered up the CPU box and Super Eagle (assuming that it boots from that drive).
The 12V rail indicator didn't light up, but the 5V did. Then there was crackling and smoke. Turns out one of the varistors went out. I replaced that today and fired it back up. Both 12V and 5V measure fine with no cards in it. I put the cards back in and found that my 12V rail was out, again. I removed all the non-essential cards (all but RAM, CPU, serial interface, and drive interface) and sure enough, that fixed the issue. So one of the other cards probably has a shorted tantalum cap on the 12V rail.
I hit the boot button on the front panel after connecting a VT-220 up to it. I get a backwards '?' sometimes. Maybe my baud rate is off? It says "2400" on the card itself, but perhaps it was changed. I tried 2400, 9600, and 19200. In any event, I don't think there's much activity, as it doesn't seem to respond to keystrokes. Who knows. Maybe my terminal is bad too. Haven't checked this one out thoroughly yet.
Maybe it doesn't even boot from the Super Eagle first. It's an Emulex SMD interface. There are two Emulex SMD interfaces, one for the big CDC drive, and one for the smaller, but still quite large, Fujitsu. There's also a dual 8" drive, but it seems to have some sort of parallel interface card instead of what I would normally expect to see for such a drive. I believe there's much more to this system than just a bare OEM 11/73. It looks like an S-100 chassis with a bunch more cards in it.
It seems to have a TU58, a serial-based 3.5" floppy drive, the two 8" floppy drives, the two big hard drives, and seemingly lots of telephone connectivity. I don't have any tapes or 3.5" floppies; just two 8" disks and three CDC disk packs.
If anyone has tips on bringing this system up again, I'd love to hear them. I've never done -11 stuff before, just lots of -8s.
Manuals for the Super Eagle would be awesome. It occasionally spews an error code "18" which I assume means the operator doesn't know what he's doing.
Thanks!
Kyle
Thanks!
Kyle
