Well, if you can copy diagnostic software then you should also be able to create a DOS 6.22 boot disk with the standard tools from the 'net, no?.
I only ask because the DOS disk is the only thing that's common to both systems and they both have the same symptoms.
Yes, quite possibly standard diagnostics won't work at a low level, but it can't hurt to try a few software things before giving up on the hardware and getting into a new set of challenges replacing the controller. The divide by zero error instead of a hardware error is curious; of course that may be the error code ;-)I don't know if Spinrite knows anything about XTIDE drives--remember this controller is bound to be very different.
Anyone got a Seagate ST05X controller? Does the BIOS have low-level formatting support?
Yes, I formatted an ST-325X drive with ST05X recently.Anyone got a Seagate ST05X controller? Does the BIOS have low-level formatting support?
