Thanks !
I really like to restore computers (and analog tapes recorder too
but the logabax was very tricky. The videoboard have some ker capacitors half dead, and some big wires are connected directly on the videoboard. There were a lots of bad contacts and the picture has a lots of glitches and the memory was not stable.
I decided to resolder all the card and it's not the same.
Again, the mainboard has lots of old caps and i decided also to change all, and i do not regret !
For my power supply, i'll test the fuse, because i've recapped all the power supply. Afterward maybe it could be some rectifiers or kind of. They are expected to be eternal, but my humble experience show me that they can sometime be the problematic circuits.
For my studer a80 (see my avatar) the problem was a graetz bridge rectifier, you know the one which should be immortal lol
For the 286, i did not know this beast, but i've found a video of a person who restore one, if it can either help you or give you some ideas.
(but as i see, the motherboard seems as complex/tricky as the logabax
But you know, i'm very angry about the power supply of my logabax ... the network card seemed to work and i made a XT-IDE and was about to (try to ) find a 8 bits SCSI or a 8/16 one....
Anyway it will be another challenge.
Regards.
Oh by the way, i remember that my logabax absolutely refuse to display a thing/correctly start without the 360 Ko drive connected !!! could it be that for yours ? Maybe you could add some videoboard as on the 286 i assume that the videoboard is not proprietary as the logabax.
