OS/2 install woes on 5162
pkhoury
Bandera, TX
Not sure if anyone else has successfully installed OS/2 1.x on an XT Model 286 (5162)? I've tried, both with a Gotek and a physical 1.44MB Teac drive, and both fail. I get this error message: "A disk read occurred. Insert a system disk and restart the system"
It doesn't matter whether it's IBM OS/2 or Microsoft OS/2. Oddly, I had problems booting up Xenix, but QNX for 286 works. I haven't yet tried another hard drive controller. I'm very partial to the WD1006, and would be willing to take a 601 error at boot over IBM's craptastic MFM controller.
CP/M User
Back of Burke (Guday!), Australia
Unsure sorry, sounds like you're trying to read a 1.44Mb Disk from a 720Kb drive?
My old XT computer doesn't have enough memory even for OS/2 1.x, I vaguely recall reading about 1.x needing a 286 Minimum, 386 Recomended, the 286 would need 2Mb Minimum I think. The old XT I had only supported 720Kb 3.5" Disks, the card had a set of DIP switches to configure the Drive Setup, there might of been cards to support 1.44Mb, though I never got around to those because people were throwing out their unwanted 386s/486s.
pkhoury
Bandera, TX
Negative. Trying to read a 1.44MB disk from a 1.44MB drive. The XT 286 (5162) is also not an XT. I'm honestly not even sure I understand your reply, really. It's basically an AT class machine in an XT case, but unlike the 5170, the CPU is 6MHz with 0 wait states (5170 is 8MHz and 1 wait state apparently). I also get the same problem in a 5170.
krebizfan
Connecticut
Is there any way you can set the Gotek to emulate a 1.2 MB drive and install from 5.25" disk images? I know that OS/2 1.x will run on a 5162. I also recall that IBM placed PS/2 specific hardware drivers on the 1.44 MB install media. It may be possible to patch the 3.5" install media to include drivers that let OS/2 continue loading for 3.5" disks on a 5162 but I don't remember how and I can't find an OS/2 1.x information source on that.
The only IBM 5162 I saw OS/2 used on did not have a 3.5" drive so I have no direct experience with that combination. How far along the install process do you get before getting the message?
pkhoury
Bandera, TX
The message appears before the disk even tries to bootstrap. I haven't tried a PS/2, but I also don't really have a usable PS/2 (I've been trying to sell off most of my PS/2 stuff, keeping a few things here and there). I can get the same disks to work on a ThinkPad, but IIRC, they won't work on a non-IBM BIOS machine. MS-OS/2 works fine. I suppose I could try and get 5.25" images and see if that works. I also thought of installing to a PS/2 and then imaging the hard drive with David Gesswein's MFM emulator, then use that file on my DREM, though there's no guarantees that will work, either.
