Today I tried booting the machine but it didn't work. I had the M8655 server board configured as 19200-8-N and 2 stop bits (SB and W4 removed).
The console M8655 is 9600-8-N 1 stop bit. On the OS/8 server disk I only get the "Booting..." and "Done sending block 0".
The pdp keeps running but it doesn't seem to be sending anything to the server so it just keeps waiting.
I noticed that the first EMA light turns on and I checked this video:
https://www.youtube.com/watch?v=9qHrEkjavUc
And the light never turns on, I have no idea how to find the problem, any ideas?![]()
A zero ohm resistor or wire jumper should be inserted at either W2 or
W5, but not both. This selects the highest baud rate the board will
support.
W5 (left) - 19200 baud
W2 (right) - 9600 baud
The original GI UART could only handle 9600 baud; the SMC COM 2017 UART
used on later boards can handle either baud rate.
// 03/04 40/41
0: 7001
1: 6046 6416
2: 6041 6411
3: 5002
4: 5000
//Echo on terminal
// 03/04 40/41
201: 6032 6402
202: 6031 6401
203: 5202
204: 6036 6406
205: 6046 6416
206: 6041 6411
207: 5206
210: 5202
From the KL8JA notes document:
Code:A zero ohm resistor or wire jumper should be inserted at either W2 or W5, but not both. This selects the highest baud rate the board will support. W5 (left) - 19200 baud W2 (right) - 9600 baud The original GI UART could only handle 9600 baud; the SMC COM 2017 UART used on later boards can handle either baud rate.
So it mainly depends on what UART device is in your board. It is the large 40p device.
All versions of M8655 should work at 9600baud; I would recommend going with that rate to start.
Set the M8655 as one (1) stopbit and 9600 baud. You could then try with one or to stopbits in the serial disk configuration. First try try to connect the board to a serial port won a PC and start a serial console and verify that you can get charters true.
First try:
Code:// 03/04 40/41 0: 7001 1: 6046 6416 2: 6041 6411 3: 5002 4: 5000
The a simple echo program
Code://Echo on terminal // 03/04 40/41 201: 6032 6402 202: 6031 6401 203: 5202 204: 6036 6406 205: 6046 6416 206: 6041 6411 207: 5206 210: 5202
If this doesn't work, try to measure the output from the M8655 with an oscilloscope if you have one.
