| VCF SoCal | Feb 14 - 15, 2026, | Hotel Fera, Orange CA |
| VCF East | Apr 17 - 19, 2026, | InfoAge, Wall, NJ |
| VCF Latam | Apr 24 - 26, 2026, | Bahía Blanca, Argentina |
| VCF Pac. NW | May 02 - 03, 2026, | Tukwila, WA |
| VCF Southwest | May 29 - 31, 2026, | Westin Dallas Fort Worth Airport |
| VCF Montreal | See you in 2027, | RMC Saint Jean, Montreal, Canada |
While it would certainly be optimal to replace the part, I've had good success with grinding into the body just above the stub (dremel tool) and soldering on a small piece of bus wire to replace the pin.Iso- a good charactor generator rom for an osborne 1, or someone that can make a programed one. My numbers were
7A3007-00
Rev A.
D7A6 OCC
Mine had a leg broken off when i got it.
Thanks, I never knew about this site.
Ive tried that with this particular one. My symptoms went from vertical lines, to vertical lines made of square boxes once the connection was made.While it would certainly be optimal to replace the part, I've had good success with grinding into the body just above the stub (dremel tool) and soldering on a small piece of bus wire to replace the pin.
I checked the images, they are the same so either should work.I see two at that link, but they both say 80 column. Is that right? And if so, which one?
Dear @ldkraemer
