ThisPostContainsComputers
Hello,
Since VCFMW is coming up in a few short weeks, I've been spending a decent amount of time getting my hardware in order. One such piece of hardware is my Otrona Attache CP/M luggable. For the most part, it works perfectly fine. Keyboard, PSU, CPU, floppy drives, etc... all seem to work. However, the longer that the machine is left on, the dimmer the internal CRT display gets. It takes about 15-20 minutes for the display to become illegible even on the highest brightness settings. I should note that it looks perfectly fine when the machine is first powered on.
If the machine is left off for a little bit and then turned back on, the brightness issue resets. This makes me fairly confident that it is a heat related issue. Additionally the external composite output of the computer does not decay, which makes me think that the issue is in the internal analog CRT circuitry.
My money is on a marginally functioning component that stops working when it heats up. Anyone got any ideas on how I can figure out exactly what is going on?
Thanks
Thanks
