harry
While adhering to the stay at home rules, I decided to dig out some older projects, among these, the IBM P70 portable seemed like a good idea. I knew the floppy drive needed attention, but as I recall was otherwise working , I switched the P70 on and was greeted on screen with usual error codes, but otherwise seemed ok. I left it on for about 5mins while I checked over the already removed floppy drive. Turned it off for approx 5mins, when I turned it back on, this time nothing on screen, no beeps, hard drive spinning, green power-good led on, but no post?
I have been searching for tips on this, and it seems a problem with no easy fix. The tech manual's advice .. "Replace system board". I have removed, cleaned the system board, reseated all, cleaned up everything, I have now come almost to the last idea that maybe the roms are the cause, if not maybe the CPU , AFAIK, at power on, after the power good signal, the Bios roms first check memory, if ok, the rom bios code is loaded into memory. I have removed, and swapped the simms around, and even tried to boot with no memory, just to see if it will respond or complain with some beeps, but nothing? All psu dc outputs to m/b and plasma screen supply are very good, well within spec.
I do have some 27512 eproms, and if anyone can help or direct me to the two bios rom codes,( ROMs 65x1565, 65x1566, if their codes are in fact available), I can try to burn new roms. Any other ideas, or resolves much appreciated.
Harry
Harry
