pinkdonut666
So recently I picked up a leading edge Model D that had been dumped off at a recycling center.
As you can see the machine was in very sorry shape. I was able to get it completely functional hardware wise, but I really wanted to do something about the case.
So I ground down the rusted areas with a 3M roloc disc on an air die grinder, there was actually alot of small bubbles that hid large rust patches underneath the paint.
I used this Product to neutralize any of the rust that remained. It's basically just phosphoric acid & isopropyl alcohol. The phosphoric acid turns the Iron oxide to iron phosphate (black shale like) and stops it from spreading. I didn't wanna have it bubbling up again.
and this is the somewhat finished product after a few coats of Rustolium 2X ivory Bisque spray paint. looks pretty good IMO.
now the question is whether or not I want to attempt to retr0brite the front bezel & keyboard. I'm going to leave it until the weather warms up at the very least (-20c here with 2feet of snow) so not ideal weather for retr0briting outside. But even then , not sure if i'm going to bother. The yellowing sorta gives this machine an aged charm. so I'm on the fence.
(I didn't paint the black bezel in this photo i actually found a beige bezel that matched the floppy drive better.
