Great Hierophant
Floppy disk based PC Games went through two phases of disk-based copy protection:
1. PC Booter - These games came first and did not require DOS to boot or run. DOS cannot read these disks and cannot copy virtually any of them. No known PC Booter required more than 2 360K disks or 1 720K disk.
2. DOS Key Disk - These games require DOS to function, but only work on their original floppies or require the original be inserted into the drive before running off a copy or from the hard drive (if the latter was allowed).
My question is will software based copying tools, such as Teledisk and CopyIIPC & Snatchit, be sufficient to make duplicates of the games and images that can later turned into protected disks? Or will a hardware based solution, such as an Option Board, really be required?
I know that if I were trying to copy business-based software, an Option Board probably would be necessary, as those software packages were more expensive and in many cases probably had stronger protection methods than games.
