Last weekend I've picked up the PDP8/A. It seems to be some sort of OEM machine, used in an special application. There is no normal mains cord, but it is made to connect into some sort of bigger machine. The Blue, Brown and Yellow/Green wires are for the mains voltage supply.
The DIP-16 cable connector, inside the machine to connect the limited boot panel, has a jumper socket in it. And at the rear of the backplane are some modifications. So I think this machine will boot automatically or the boot is triggered through the other external cable.
I've visited Henk and he magically has two of these limited boot panels. But the mechanics and electronics are different as well as the text on the front.
The left panel has a battery charging function and the right just has DC-OK. I think the battery version should be suitable for my machine since it has RAM instead of core memory... But I'm not entirely sure.
Here you can see the back of the panels. The top one seems to be made for a big cabinet and the lower one fits on my small case.
My machine is a 8A400-BR (On a label is written: Product variation: Model changed. From: 8A400-AB to 8A400-BR)
Does anyone know where I can find the documentation which describes these modifications? I found some 8A500 documentation... But I'm not sure about the differences between these two.
The boards inside the machine are,
8315 - CPU
8317 - ext mem and bootloader
8316 - multi function board
8417 - 32KW memory
There are two ROM's on the bootloader board, but the labels are gone. I have to read them, I wonder what bootstraps are inside them. Maybe these were application specific too.
Still searching for an octal frontpanel for this machine.
Regards, Roland
