MauriceH
For couple of day's I am struggling with my PDP8/M and the Timing Control Board M8330.
T's definitive this board , because with an other M8330 the machine is working fine.
The problem is, the PDP8 will not read in From Asynchrone M8655 (1200Bd), Terminal VT220.
Did all the toggle in tests 20 till 37. (The known toggle in written test paper).
It reads in the M847 Bootloader card.
It print characters on screen,
But it fails to run prog: 33 the 03/04 adress Echo test and the
test 37 Keyboard read in test and display on AC the typed character.
All other tests like microinstruction test 1&2, operate instruction, ISZ, JMS,JMP,Vissual AC Incr.,Checker Board runs perfect as aspected.
What causes that the M8330 wil not start read in Data from M8655?
Also it runs the maindec-08-dhkaa without errors (The read in I did with the working M8330),shut down machine,
swap boards,start pdp8 and run the program.
At display the code printed "HC" with SW=0003 (fast test), Same as with working M8330.
Any idea's where to look for the failure.
