Mike_Z
A year ago or so, I was working on a code converter for my Friden Flexowriter to be able to communicate with my PDP8E. At that time I had the circuit built on a few breadboards with an RPI. The entire mess seemed to work rather good. Since then I developed a PCB from my KICAD drawing and sent away for a PCB board. Amazingly, my PCB board only had one mistake on it. For some reason, the back side edge card connector was covered with mask. I had copied the front pads to the back and forgot to change the front masks to back. So, I scraped the mask off, installed the parts and the board worked. Will wonders ever cease? This past week, I have been 'tuning' the RPI code to allow the Friden to work better. I had to slow the byte rate down a little, because the key lock would lock out the Friden on occasion. This Friden circuit is used to block two keys from typing at a time. I think the RPI was sending key codes to the Friden too fast. Well, after adding a 15 millisecond delay, the majority of the lockouts vanished. I still get maybe one lockout per full page of text.
I have found the when asking the PDP8E to type a file 'TYPE MPH.FT'. This particular file would lockout at the same point in the file every time. It would occur at the end of the file. This makes me think that maybe there is a particular character causing this problem. Is there a way I can look at each character in a DEC file? Seems that this character is not a printable character. I'm going to make a text file with all the ASCII characters 0-127 and see if one of those causes this problem, but I'd still like to see what the PDP8E is sending to the RPI code converter. Thanks for the help, Mike
