fjk61011
I've found os/2 drivers for my XIRCOM POCKET ETHERNET III adapter. I'll try and get that working tomorrow
You may as well skip Win 3.11 and WfW 3.11 and go straight to Win95 OSR 2.x. Linux and the various BSDs are also options.SUPER MICRO
P6SBU
With Pentium II
It has 3 onboard SCSI ports. Two onboard IDE ports and onboard Floppy drive port.
there are 2 SCSI CD-ROMs and one SCSI HDD.
Booting this PC checks RAM and passes.
However, WAIT ...
And a flashing cursor. Nothing happens for about 10 minutes and continues to error message about IDE drives. I went into the BIOS and disabled the IDE ports and all is well. I might put WfW 3.11 on it or maybe win 95.
Most of the Supermicro P6 boards run both PIII and PII CPUs. From the manual:Don't the Supermicro P6 boards run P3s?
The SUPER P6DBS/P6DBE/P6DBU/P6SBU/P6SBS/P6SBA/
P6SBM supports CeleronTM SEPP 266-433 MHz, Pentium® II 233-450 MHz
and 100 MHz FSB speed Pentium III processors up to 700 MHz. (*Note:
Currently, SUPER P6DBE/P6DBU/P6SBU/P6SBA motherboard supports CPU
speeds up to 1GHz with 100MHz FSB speed.)
Well, OS/2 comes with IBMINT13.I13 which uses the INT 13h interface. I've never used it, and it surely won't be fast (shouldn't matter on an 8-bit data path, though).XT-IDE with OS/2 and a Pentium? Not a chance, I'd say--unless you can find a OS/2 protected-mode driver for it. I'm not aware that anyone bothered to write one.
