Pictures of the Tandberg TDV-2114
per
Western Norway
I have now been able to take pictures of the Tandberg TDV-2114 computer. I realized that there were 5 more cardslots on the other side of the monitor, and 4 of those were populated.
The complete list of cards are:
Floppy disk       K-82885-0 (supports two 8" SSSD drives)
Cluster interface K-92619-2 (Supports seven I/O ports for cluster terminals, three of them seems to have some kind of direct CPU I/O support)
RAM               K-92615-1 (16KB RAM of the Intel B2107B-6 kind)
PROM-CR-PT8       K-92780-2 (has socets for up to 16KB of ROM, curently none of them are being used)
RAM               K-31022-1 (48KB RAM of the HYB4116 kind)
Display 1         K-92647-4 (Monochrome graphics, part 1)
Display 2         K-92651-5 (Monochrome graphics, part 2, contains 4KB of P2102A-2 video memory, 4KB of D3624-4 graphics ROM and a pushbutton to invert the display)
CPU               K-92539-4 (Contains an 8080, 4KB of P2102A-4 RAM, and 4KB of boot ROM.
Pictures:
RIMG0361.jpg = External disk drive front
RIMG0362.jpg = External disk drive back
RIMG0372.jpg = RAM card with 48KB of RAM
RIMG0365.jpg = Cluster interface
RIMG0363.jpg = Floppy disk drive controller
More pictures:
RIMG0367.JPG = RAM cards with 16KB of RAM
RIMG0369.JPG = Unused ROM card
RIMG0375.JPG = Display adapter 2
RIMG0373.JPG = Display adapter 1
RIMG0379.JPG = CPU card (note the blue wire going to the left; that's the loose one)
The last round of pictures:
RIMG0377.JPG = Right card slots without cards
RIMG0378.JPG = Left card slots with cards
RIMG0385.JPG = Back cover
RIMG0391.JPG = Correct setup
RIMG0387.JPG = System unit without cover
I also ran a test of the system without the CPU card. The result can be seen here (read the descrpiton):
http://www.youtube.com/watch?v=dSj1KZsCTUA
I know its an old thread, but I am finally getting one of these myself.
Additionally, I see that Siemens later released this platform as the 6.600 series. If anyone happens to have any documentation (even if it's in German), I would be very grateful to see it.
Hello Per!
I got a message that someone used the disk-images I made many years ago of two 8 inch floppy disks actually booted a TDV-2114 (or Siemens 6600?). Somewhere I think I have some more disks. The content is probably about the same though.
There is a German forum l got directed to for the discussion on this topic: https://forum.classic-computing.de/...39-siemens-6-610-reparatur-geglückt/&pageNo=1
But perhaps you know of this already.
When I saw the pictures of the boards above I sort of recognise them. I think I have a bunch of similar looking boards here if you are interested. I can get pictures of these boards in the weekend. Trade for something interesting...
Hello Per!
There is a German forum l got directed to for the discussion on this topic: https://forum.classic-computing.de/forum/index.php?thread/25639-siemens-6-610-reparatur-geglückt/&pageNo=1
Yeah, I found that thread shortly after I posted here.
..And please do! I would be very interested if you have spare boards.
I have three board that look similar:
Two marked Tandberg and one marked Intel.
Aha! Now I only need a Tandberg emulator to run all this on ... 😁
I got expansion RAM boards working in MAME recently, but it's still some time before I get as far as to actually getting some sort of floppy expansion module in there. That one requires a lot of work, since it's running on a full custom discrete-TTL based microcontroller, and able to access the system memory on its own using DMA, etc...
