M maxfli Experienced Member Joined Oct 21, 2012 Messages 179 Aug 19, 2021 #1 Does anyone know the type of connector or part number for the cable to go from The video card PMAG-B (turbo channel, alpha system) to a monitor? Thanks in advanced.
ajacocks VCForum Administrator Staff member Joined Jan 21, 2011 Messages 1,424 Location Middletown, Maryland USA Aug 19, 2021 #2 I'd assume that it's 3w3, like most DEC video cards: https://www.ebay.com/itm/DEC-PMAGB-...-FRAME-BUFFER-GRAPHICS-54-21143-/251507110200 One pin is red, one green, and one blue. Sync is carried on green. Just find a 3w3 to VGA adapter, or a 3w3 to 13w3, depending on your monitor. - Alex
M maxfli Experienced Member Joined Oct 21, 2012 Messages 179 Aug 19, 2021 #3 That’s the connector 3w3, now just finding one.
P PG31 Veteran Member Joined May 31, 2011 Messages 509 Location Sefton, Meresyside, England Aug 19, 2021 #4 Had to sort this out last year, you'll need something like 17-02906-01 BC29G-09 and then BNC to VGA Cables 4 ALL 1m BNC to VGA Male Cable Shielded Video Cable 3.28ft 5060416877578 | eBay DEC RGB Monitor Lead - Digital VW-1 Low Voltage Computer Cable - BC29G-09 | eBay Your monitor will also need to be capable of sync on green Last edited: Aug 19, 2021
M maxfli Experienced Member Joined Oct 21, 2012 Messages 179 Aug 21, 2021 #5 Does anyone know what the part number/model number hard drive will fit in a DEC AXP 3000/300 system? I know its a 50 pin scsi drive.
B bqt Veteran Member Joined Sep 15, 2019 Messages 506 Location Zurich, CH Aug 22, 2021 #6 maxfli said: Does anyone know what the part number/model number hard drive will fit in a DEC AXP 3000/300 system? I know its a 50 pin scsi drive. Click to expand... Any SCSI disk with a 50-pn connector? Or with an adapter to a 50-pin connector?
P PG31 Veteran Member Joined May 31, 2011 Messages 509 Location Sefton, Meresyside, England Aug 22, 2021 #7 SCSI2SD is a good way to go. SCSI2SD - SCSI2SD.COM
M maxfli Experienced Member Joined Oct 21, 2012 Messages 179 Aug 22, 2021 #8 The system has an internal 50 pin scsi interface.
