leeb
As the title suggests, I open the question of cable repair on our older devices.
The background:
I have been 'dabbling' in the older Tandy/Panasonic 286-on laptops for... quite awhile now.
One of the major problems has been the age-related self-destruction of the drive (Matsushita EME-263/273-somethings) belts.
Some sources had been tapped for this but I believe I have recently found a reliable (tho expensive) supplier.
The issue for discussion with these drives lies in the design of the ribbon cables attached to their control boards. I would hardly describe them as flimsy... however I have realized that many of the drives I have held back for lack of drive belts also have contacts that have delaminated from the stiffer 'insertion edge', such as this:
I apologize for the poor images... will attempt retakes during the day.
While I have avoided too much manipulation of these units to prevent breakage of the contacts, I have been contemplating the best way to reattach the separated contacts to their backing surfaces.
I have considered:
Super Glue
... Because it is best on NON-POROUS (AND inflexible) surfaces, I fear it is a bit too rigid for even the insertion edge, and would break loose after one or more dis/connects.
RTV/Silicone adhesive
... While many RTVs provide good-to-excellent adhesive properties, their main failing is in 'shearing forces'... those that cause 'sliding'. I doubt the contacts would remain immobile for even one insertion/removal sequence.
This is as far as Ive gotten to this point... If anyone has suggestions or known repair methods (or hair-brained schemes ) that I have not heard of (obviously) I would appreciate your input!
Lee
:D
The background:
I have considered:
Super Glue
Lee
:D
