Old Thrashbarg
I recently picked up a couple external SCSI Zip drives, with the idea of using them as boot drives for some of my old machines. Unfortunately, there's a troublesome little detail that I'd forgotten about these drives... they only have two settings, ID5 or ID6. For use as a regular external storage drive that's fine, but it presents a problem if I want to boot from them, as a fair number of old SCSI controllers expect the boot drive to be at ID0.
So I've been trying to figure out a way to modify the things to use a different ID. At first I thought it would be a simple matter of cutting a couple traces to get ID0/1. Judging by the way the jumpers work on most SCSI drives, I figured there would be three lines for the SCSI ID, one would be permanently tied to ground, and there would be a SPDT switch on the other two that would alternately ground them. But it appears that Iomega didn't make it that easy... there's only one line coming to an SPST switch, from the custom Iomega 'Phaedrus' chip, which is open for ID6 and grounded for ID5. And since there's no data available on that chip, I've kinda hit a wall. I suspect the key may be to look at one of the internal SCSI drives, but that would require having an internal SCSI Zip drive, and those things are quite difficult to find.
Now, there's no way I'm the first person to think of doing this, but has anyone ever actually done it, or am I wizzing in the wind here? I've Googled just about everything there is to Google on the subject, and I've come up empty.
