Possibly getting an M24 - keyboard options
bobba84
Melbourne, Australia
Hi guys,
I'm currently looking at getting an Olivetti M24 for pretty cheap... but it's box only! I know i can work around the monitor issue but what about the keyboard? Do I need a genuine one? Or are there other options?
Thanks in advance!
Try it with an adapter, but the BIOS selftest also includes the keyboard controller, so hopely the 3rd party keyboard will not fail. Otherwise, sometimes there are single M24 keyboards on eBay & Co. You also can use the keyboard of M240.
The voltage regulator in the adapter is important, as the M24 keyboard connector supplies +12V.
Ok, so I got the M24. I can hear it beep and the floppy light comes on, so I think it is at least partially working.
I've made the VGA adapter cable posted here but get no output on an LCD. I'm guessing it can't handle the signal...
I'd like to put an 8-bit capable VGA card in. I found info here about removing two PAL's to disable the on board video? Does anyone know exactly which two? And what motherboard DIP switches work for VGA?
Thanks in advance! I'll hopefully have my childhood computer again!! :D
Is the monitor you need a VGA one with a bunch of pins missing? I just happened to have picked one of those up recently for $6 (AT&T branded). I live in the U.S. though.
The original M24/6300 monitors have a DB25 connector. So any with 9 or 15 pins is not the original.
I would not try another VGA card in there before you know if the M24 is functioning or not. This is because of plugin a VGA card into the M24 without removing/bridginmg the PAL you may damage the machine.
As it does not come up, get a post diagnostic plug for the parallel port of M24 and follow this thread: http://www.vcfed.org/forum/showthread.php?54605-How-to-read-parallel-port-POST-diagnostic-codes The discussion has several pages and somewhere on 1st page I posted a link to such a diagnostic module (costs about USD 5), trixter found all of the codes in BIOS disassembling and on follwoing pages somewhere I posted the full diagnostic codes of the M24.
While a diag module and checking the codes will give piece of mind to any M24 owner, the fact that he's getting a beep and the floppy drive is lighting up suggests to me that he's completing POST successfully.
I agree do not attempt to put a VGA card in until you've got all other issues resolved. If your existing monitor didn't take the VGA adapter connected to the existing video port, then make sure you've got it wired up correctly, and then try a different monitor. Sometimes older monitors will sync to odd signals better than newer ones. Find a glass CRT VGA monitor as that will always work.
Thanks for the replies guys!
I may have already tried a vga card in there :( hopefully I didn't do too much damage.
I found the info in the manual about disabling the factory video card. Something about a P4 needing a shunt with connections instead of the PAL but the P8 just needing jumpers changed. I'll have to figure out which card I have and give it a go.
But yes, I believe it's working fine as I can hear the post beep and floppy trying to access.
I'll post back with what built in video card I have and how I go disabling it.... but does anyone know if my BIOS will support the VGA card? The ROM chips say 1.1 in big writing on them.
Thanks,
Bobby.
Update - Forget about the VGA card, I tried another older LCD and I got video!
It POSTS, but won't boot. A few times it froze randomly on startup but after running a while it seems to reliably finish POST but won't actually boot. It just sits there forever with the floppy light on. I've tried without the MFM card, without the video or keyboard adapter connected, etc but it never gets past there.
I also tried another floppy drive and cable, and a few different boot disks.
Power supply reads 4.95v, 11.7v and 16v
From memory this is how it behaved when I first got it, I tried booting with a disk (blindly) but never heard the drive changing tracks.
Any ideas guys? :)
ANOTHER UPDATE: After removing and reseating the keyboard controller chip, it boots!!! I just can't get the keyboard to work... I'll have to check my adapter :)
Thanks for your help as always :)
No luck with the keyboard :(
I'm pretty sure my adapter is correct, I usd this guide and I've joined pin 1 of the M24 to DATA, pin 2 to CLOCK, pins 3 and 4 to GND as well as the centre leg of the LM7805, pin 5 to the input leg, and it's output leg to +5V... it boots to a DOS prompt but as soon as I press anything the PC speaker goes mental doing constant tones. I've tried 4 keyboards including XT and AT switched ones in both modes and a genuine IBM type M.
Update: Tried all 8 keyboard I could get my hands on. Some cause the POST to freeze, some don't. Keyboards with lights will flash once when powered on.
Any ideas guys? :)
Thanks!
Yes, you're not doing anything wrong, I believe. The reports of an XT keyboard working with an M24 are anecdotal--and I could find no solid confirmation of it. While the scan codes are the same, there is one key difference--and I think it may be holding you back. The M24 keyboard is bidirectional; that is, it can receive commands from the M24 and return responses.
That's just a guess, however. What happens if you try to boot with the keyboard disconnected?
Typically you needed 1.43 for external video card support, but if you got it working, all power to you :-)
The 6300 keyboard is not the same as an XT keyboard; the voltage is different. See ftp://ftp.oldskool.org/pub/drivers/ATT/6300/keyboard_pinout.pdf and ftp://ftp.oldskool.org/pub/drivers/...livetti_M21_M24_Theory_of_Operation_Nov84.pdf (page 180) for more info. Not sure if that matters, but it might.
I believe this is why you need a real M24/6300 keyboard. I've never seen any evidence that an adapter works either.
I wonder that it does not boot from the harddisk. Two things to help:
1. You have very old BIOS (1.1), the latest was 1.43. (Be carefull, when updating the Bios, the meaning of some Dip-switches change!)
2. What are the dip switch settings for the hard disk? Use internal hdu support or hdu-controller bios?
I got the built in video working through an adapter, not a VGA card :)
The HDD that is came with is dead, I put an ST-225 in there but it hasn't been LLF'd on this controller, as I can't type anything.
Sounds like I'm stuck without the correct keyboard... Might have to put a wanted post up!
My next mission is to make a boot disk that redirects i/o to the serial port and use a terminal emulator to do a few tests.
Thanks guys :)
Hey, that's actually pretty clever! You might even be able to run some older "MS-DOS compatible" applications just fine that way until you find an M24/6300 keyboard.
