Powermac G3 Restoration Software Will Not Recognize New Hard Drive
Hi,
I'm restoring a PowerMac with the Original OS 8.5 CD. The original HDD is clicking. I've tried to mount a few known good IDE drives, but every one kicks in the install, saying no compatible drive can be found.
Am I missing a registration step, or do I have to initialize a specific file system?
The system does successfully find the old disk when it tries to boot, so I don't think I'm hitting a south-bridge or other motherboard related issue, but I can't seem to google up a thread where anyone else had this problem.
Apple's formatter at the time had a whitelist of "supported" drives. Any drive will work, really, but you had to use either a third party utility to prepare the drive or use ResEdit to patch out the whitelist.
Thanks! I'll look in to ResEdit. If there were prep tools, Do you know if I can initialize a new disk via a disk clone from the clicker, to pull off the drive ID and partition table? Or does the drive have to get white listed to the motherboard?
I'm trying to recall my steps when stuffing a "new" drive in mine... I believe I laid the partition map and formatted from Linux, the macOS installer did the rest after it was mounted in the beige box.
ATA drives are not restricted, only SCSI disks are.
