A positive update for a change!
Nige, I received your DRAM chips today and tried 8 of them together with the Forth Eproms. This gave me the Forth screen prompt and I actually ran a quick forth test routine for the first time in 20 years!
I then re-fiited the originals, one at a time and found to my suprise that 5 of my 4164s were faulty.
I then installed the new Basic Eproms and got the original problem with the same LED sequence and the continual tone.
So Stuart, it looks like you were spot on with your prediction.
I then dug out my original Basic eproms (Couldn't remember which one was faulty - Thought it was IC45) and tried different combinations of new and old eproms but stiil had the same fault.
But a great leap foward and my system is now working on Forth thanks to all of you.
So to the next step -
Where can I get some 4164s or MCM6665s or equivalents and where would be the best place to look - or Nige, can I buy 5 off you.
Also if I post the new basic eproms back to you together with my originals, would you mind testing them on your system for me.
One last question, the new Eproms were labelled
Cortex 1 EB84
Cortex 2 149E
Cortex 3 72EB
and I put them in sockets 47, 46, 45 respectively, as instructed but what are the hex digits, are they eprom checksums or do they refer to a memory map?
