Stuart,
I've re-checked all the pins and listed the indications below. The random pulse I was seeing every 3-4 seconds on A0 + A5 seems to have disappeared - Maybe it was my probe randomly triggering. Also the data pulse on A11 seems slower or a different format to that seen on other address pins - If this means anything.
ADDRESS LINES
The address line results can be divided into groups:
A1, A2, A3, A4, A6, A7, A12
Without touching the reset button these are continually pulsing.(high, low and pulse lit)
With the reset button held in, these address lines are LOW and start pulsing when RESET is released and then remain pulsing.
A0, A5, A8, A9, A10, A11
Without touching the reset button these are showing LOW
With the reset button held in, these address line are LOW and start pulsing (high, low and pulse lit) when RESET is released, but only for the length of time that the RUN led is lit, then they return to their normal state of LOW. * (ON A11 THE DATA PULSE SEEMS TO BE SLOWER THAN THE OTHERS)
CS1 (x3) = Initially pulsing High / Low -- Reset button in = High --- Button released = Pulsing High / Low
CS2 / IC47 = High initially, High when RESET held in and pulses for short duration when RESET released - Pulsing stops when RUN led goes out.
CS2 / IC46 = High initially, High when RESET held in and pulses for short duration when RESET released - Pulsing stops when RUN led goes out.
CS2 / IC45 = High initially, High when RESET held in and pulses for LONGER duration when RESET released - Pulsing stops when RUN led goes out.
PD (x3) Continuous Low = Uneffected by reset
Voltage between pin 14 and pins 1/26/28 = 4.85v - All Eproms
Q1 to Q8 = Initially High -- Reset button in = High --- Button released = Pulsing High / Low for duration of RUN led then continually High.
I also had a quick check of :
Pins 11 to 18 of IC44 = Initially no indication on probe -- Reset button in = No indication -- When the Reset Button is released, these are active for duration of RUN led then back to no indication.
Pins 5,6,7,9,10,11,12,13 of all the RAM chips = Initially pulsing High / Low -- Reset button in = Low --- Button released = Pulsing High / Low (High LED brighter for duration of RUN led)
The continuity check between the Eprom pins was also all good.
Andy
