M maxfli Experienced Member Joined Oct 21, 2012 Messages 179 May 19, 2022 #1 I have an Apple IIe, Apple IIc+ and Apple III. I want to have one ImageWriter printer connected to the three Apple computers with a manual selector switch. What type of switch do I need?
N njroadfan Veteran Member Joined Jan 21, 2011 Messages 1,642 May 19, 2022 #2 A DB-25 switch box for RS-232 serial use should work fine. They come in 2-way and 4-way varieties. Just be mindful of cabling issues.
M maxfli Experienced Member Joined Oct 21, 2012 Messages 179 May 20, 2022 #3 Thanks, I guess the question is now what type of DB25 cable should be used? Null modem, straight through, etc.?
N njroadfan Veteran Member Joined Jan 21, 2011 Messages 1,642 May 20, 2022 #4 Printer cables should be null modem wired. The Super Serial Card if you machine has one can be set to whatever mode you want too. Pin outs for your various machines are here: https://adtpro.com/connectionsserial.html
