Thanks Chuck(G).
Tried 2 local shops - did not have a modem.
I believe I have a NEW PROBLEM WITH FLOPPY DRIVE...
I booted the machine and attempted to format several old floppies so I can back-up my original system disks. I ran a DIR on the floppy to see if there were files on it and there were none. After chugging along and making a lot of noise formatting the first disk, the results came back with:
1213952 BYTES TOTAL
744960 BYTES UNAVAILABLE
468992 BYTES AVAILABLE
These results didn't look quite right, but I went on to format the second disk (Disk-#2). The result was a "FORMAT FAILURE". I tried to see drive A; and received the message:
"GENERAL FAILURE ERROR READING DRIVE A
ABORT, RETRY, FAIL?"
I rebooted the machine, changed drive to A: and ran a DIR on another disk (Disk-#3). This disk also had old files on it. Tried to format the disk and got a "FORMAT ERROR" once again. Got to the A: prompt; reinserted the "bad disk" (Disk #3), and got the same error message:
I repeated the same process two more times with the same result.
I then ran Norton Disk Dr. from the HD on a couple of these "Bad" disks: It tells me:
UNABLE TO DETERMINE DISK TYPE IN DRIVE A
Asks what type - I entered largest type on list.
DOS BOOT RECORD IN UNREADABLE
THE BOOT RECORD IS PHYSICALLY DAMAGED
A LOW LEVEL FORMAT MAY BE THE ONLY WAY TO CORRECT THIS PROBLEM
I didn’t proceed with the low-level format; went on to the next test. Message:
ERROR READING A SECTOR IN THE FAT
THE FAT HAS A PHYSICAL ERROR.
THERE ARE 2 COPIES OF THE FAT. THEREFORE YOU HAVE A SPARE BUT IF BOTH GO BAD, YOU COULD LOOSE FILES.
CORRECT? – no
Next test. Message:
THE FAT IS PHYSICALLY BAD. FURTHER TESTING IS NOT POSSIBLE.
It appears that the Floppy drive is eating up my disks… Kind of explains the DOS and ND disks becoming unreadable. Age or drive problem?
I’m now wondering if I should be looking for another 286 or 386 box as was suggested earlier (i.e., 12MHz – 16MHz).
Thoughts?
