algofoogle
Howdy folks. Nice work on these ACU card designs! @whaka and @Theoryboy, I'm glad you're working on this.
Do you think you will release either of your designs as Open Source, maybe even just publish your EDA or PCB design files? Or do you expect you'll just treat this as a commercial project?
I'm tinkering around with my IBM PS/1 model 2011, and I am interested in trying to make my own breakout/dev board for the ACU slot -- I gather it uses the same mechanical specs as a PCI slot, but I note that it has 112 pins (I think; 56 x 2) instead of PCI's 120 pins (or whatever it is). Do you have any specs for this that you can share?
In any case, keep up the good work! Cheers
